- 2
Hi All,
I've just bought a new Arlo solution with 3 X Arlo HD cams and integrated it with my Alexa system which uses Echo Shows. When I say the command to view any of my cameras with Alexa it just hangs saying "Waiting for Netgear" for about 20 seconds then times out.
I am aware of the workaround to have to say the command twice which does generally work but has anyone got a permanent fix for this yet? Have Netgear addressed this?
25 REPLIES 25
"The engineering team is investigating this issue"
- 2
