  • 633 Views
chubafelix
Hi There, I understand that my installation is not typical but if someone has a good understanding of my setup, I would very much like to hear your opinion on this working on not.
I have a 4 apartment building and the front doors are far from where you would typically have wifi router. Thus, I wired a router very close to where the front doors are and I am attempting to connect all 4 Arlo video doorbells (wired) to the same router. So far, I have one working and the other 3 fail during installation. I am using the same Arlo app on my phone as I used for the first doorbell (working). Should I be able to install and connect 4 doorbells on one Wifi?
Secondly, can I setup the 4 doorbells under 4 separate email accounts (for privacy) but still use the same WiFi router? Another words, for each doorbell, I would login with account 1 and set it up to the one and only Wifi, then do the same with account 2, etc? Can these 4 doorbells work on 4 separate email accounts but through the same Wfi router?
Thank you
Felix
Have you tried resetting those failing doorbells?
https://kb.arlo.com/000062934/How-do-I-reset-my-Arlo-Video-Doorbell-Arlo-Secure-4-0
That would work fine. The router would not be a problem.
chubafelix
Thank you very much for your responce.
I will try the reset button when I am back at that location.
One other question as it relates to my multi doorbell setup.
If I setup this doorbell on my email address and the associated Arlo account, what is the easiest way to hand this over to another individual (my renter)? Do I need to go through the entire installation from scratch and have this person establish a new Arlo account in the process? Or is there a way for me to just change to another account within Arlo App?
Thank you, F
You could create an account using a "sacrificial" email address.   Then change the email/login to the desired user later.
  • 634 Views
