Chime 2 connection
Had a real problem connecting the Chime 2 for second time,it was working ok before ,then suddenly lost connection to the router,I then set up different 2.4 gh network, connected it ok and then it stopped working.
I tried to reset, remove and add it again and none worked.
Thanks in advance for any help
Have you tried resetting the chime?
https://kb.arlo.com/000061879/How-do-I-reset-my-Arlo-Chime-or-Chime-2
It may just be faulty so swap at the store.
@Rumen0105 what type of phone are you using to re-onboard the Chime 2 ?
Thanks for reply, phone is Nokia xr21 , been working well before
It looks like it is online as of now. Are you still seeing the same behavior?
