  • 18 Replies
  • 3579 Views
  • 6 In Conversation
iSmartTinting
Why my ARLO ULTRA live feed shows 4K but result not clear not 4k. (don’t require any subscription to view 4k live). No network issues (strong signals with 500mps download 25mps upload) same network)
18 REPLIES 18
Using the app, is the setting for 4k live view selected?
iSmartTinting
Yes, all cameras to 4k .
live streaming says 4k but results worst then my doorbell
LandJS
Mentor
Mentor
Keep in mind that 4K live is only when live.   4K recording to the SD card when set for best and 4K to the cloud only if you pay for the upper level plan, otherwise your cloud is not 4K
If you are saying it's not as clear as you expect, then try downloading an MP4 in the library, and check the resolution.
I think you will find that the video is 3840x2160.
iSmartTinting
we are not talking about saving in cloud or SD Card
LIVE VIEW only is not 4k
But the recordings are?
iSmartTinting
Recording to SD Card looks good
only live view it’s says 4k but it’s not, can’t upload videos here t on see.
iSmartTinting,
Do you have the setting enabled for local 4K live streaming? This can be found under Settings > My Device > select the desired camera > Video Settings > Local 4K Live Streaming
Additionally, your mobile device must be connected to the same network as the SmartHub/Camera to live stream 4K.
iSmartTinting
yes, all settings related to 4k on, same network, it’s showing i am viewing 4k live but results not 4k live feed slow, blur, when i switch 4k off , live feed show sooth 1080p.
iSmartTinting,
What model is the mobile device you're using? If you log in to the Arlo app using a different device, do you experience the same behavior?
iSmartTinting
iPhone Xs Max / iPhone 7 Plus
Laptop/ Desktop
live stream is not 4k stream
Arloultra
Luminary
Luminary
I’m assuming you have 3 camera’s enabled for 4K ? The reason I ask is my understanding is only 2 4K steams allows at once! I’m sure you’ve checked all streams. Have you tried 4K settings on one camera only for troubleshooting?
iSmartTinting
I know that only 2 cam can be viewed at once 4k and rest in1080p.
Even when you view only one camera video 4k but but not clear also keep pausing (slow motion) WiFi strength no problem ( if keeping close to router/smart-hub it’s same)
Arloultra
Luminary
Luminary
I feel ya. Mine’s been freezing a lot lately not to mention the audio constantly cutting in and out!
iSmartTinting
Yes, audio constantly cutting in and out too.
Arloultra
Luminary
Luminary
Unless you have a noisy scene going on most people wouldn’t even notice it unless you put your ear up to the phone!
LandJS
Mentor
Mentor
sound  is the one thing I have never had an issue with at least not sound level.  I clearly hear the crunch of gravel when a car goes by,  hear the chickens next door 150 ft. away and their dogs 200.  I hear people talking in my driveway and back door.  As for understanding every word, no but then without my aids I have a 70% hearing loss so don't expect to
iSmartTinting
Video/Sound no problem when 4k is off.
PROBLEM in only 4k mode.
  • 18 Replies
  • 3580 Views
  • 6 In Conversation
