  • 8 Replies
  • 14663 Views
  • 13 Likes
  • 6 In Conversation
orangealum
Hello,
I’m thinking about buying the Arlo ultra Camera. I also want to buy a local storage for the base. I’ve heard from one review somewhere that the max capacity the base will cap at 32 gb. Is that correct? Don’t want to be something huge when it only use 32gig. Can someone please confirm? Also hopefully all the bad reviews out there has been resolved for this Camera.
I'm using a 128GB card and others here have reported that 256GB cards also work.
8 REPLIES 8
VCG
I'm using a 256GB, no problems .
orangealum
Thanks to all that responded.  My question is more what the system will be able to handle.  If  I purchase a 256 GB micro card, will it actually use all of the 256 GB if I keep on saving the videos.  Or will it only use up to 32 GB of space as I understand the limits of the base.  Make sense?
brh
@orangealum,
It will fill up the full 256gb. The 32gb in the manual is a mistake.
Brian
Izombie
How did you format your card? I had only one option on my computer exfat and when I look at the settings, it says it needs formatted. What gives? Mine is a Samsung evo microsdxc uhs-i card
Yeah, Windows doesn't want to format large drives as FAT32. You have to use a 3rd party utility to do so. I simply put the card in the base and did the formatting there.
Izombie
I did not see an option to format from the hub. How did you do it?
n11
Here is the path:
  • Settings
    • My Devices
      • (hub name)
        • Local Storage
          • Format SD Card (button at bottom of screen)
  • 8 Replies
  • 14664 Views
  • 13 Likes
  • 6 In Conversation
