Hey i am new to arlo. and bought me an arlo ultra 4k set with 2 kamara. unfortunately can't get the siren on and work in the base some who can help. have been under armed base and adjusting time as well as strength of sound but still no luck.
greeting mikkel
greeting mikkel
With the Arlo Ultra cameras you use a smart hub and they don't have a siren. Arlo Ultra cameras have the siren in the camera. Base stations however do have a siren
5 REPLIES 5
arhh okay then i must have misunderstood it. but just don't think the alarm is high in cameramen ?:-( is it possible and get installed base station on?
You could add a Pro base for the sole purpose of being able to activate the siren.
Does the pro base work with ultra camara?
The idea is to use the base with no cameras attached so you can set rules that would activate the siren.
Accessing Local Storage
