  • 5 Replies
  • 7366 Views
  • 2 Likes
qureshibe
Dear all,
My outdoor camera is detecting wind motion & is sending me 100s of alert a day. I am getting sick of it.
I have put detection sensitivity to 50%, no resolve.
I have minimized detection zone, no resolve.
It is a defect or normal for Arlo Smart?
I don't want wind Alert,
I don't want any other motion alert but People/Vehicle
Why this thing is draining my battery & bombarding with unwanted notifications?
Any solution plz?
I thank you
Arlo Smart On OFF.PNGDetection Sensivity.PNGDetection Zone.PNGFake Alart Motion Notification EMails.PNGFake Alart Motion.PNG
qureshibe,
Adjusting motion sensitivity in "Motion Detection Test" will not change sensitivity for motion detection triggers. This needs to be adjusted in your cameras rules. To adjust trigger sensitivity, take a look here: https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
5 REPLIES 5
qureshibe,
Are all of these alerts motion triggers or are they audio triggers? In your rules do you have motion and audio set to trigger a recording or just motion?
FAZZAMJF
I have the same issue. It’s only started doing this over the last few weeks.
All cameras inside and outside started to trigger randomly and almost never stop unless I turned off the monitoring.
I noticed the 99% of the time the audio was the trigger. Watching the videos (which I still have saved) you hear nothing loud enough to trigger anything.
If you turn you phone volume to max and listen hard you can hear a buzzing / electric sound back track. Since nothing has changed in my home to cause this. Plus the timing of the last firmware updates. Im 100% sure the current firmware is the cause.
Fix = disable audio triggers on any monitoring modes.
I plan to test this again this weekend when I have some free time.
Side Note: the Smart AI was also detecting some of the clips as “person”.... erm no, but maybe a robot 🙂
FAZ
qureshibe
All alerts are motion-triggered.
Audio Trigger is OFF. I don't use Audio as I don't need it.
You can see EAR disabled on the screenshot.
Literally every minute motion trigger, recording & notifications. See Screenshot
False Smart Alert.PNGMotion Active.PNGFake Alart Motion Notification EMails.PNG
qureshibe
Smart is Zero - Another frustrating day of testing.
Sensitivity 20%
Smart Trigger - Detect PEOPLE only
In 1 hour more than 30 triggers
I have opened a case to see what they can do. As this is distracting me at work. Not helpful at ll
people only.PNGFalse Smart Alert Notifications .PNGsensitivity.PNGtrigger no smart.PNG
qureshibe,
  • 5 Replies
  • 7367 Views
  • 2 Likes
