Any luck with customer support? 2 months in and can't get subscription honored?
Has anyone had any luck with Customer support?
It seems like all promises and no action.
2 months in and can’t evem get the free years subscription honoured.
Standard. When you have an issue they run you around in circles til you cant be bothered anymore and give up.
Hi Ryang11,
Let me reach out to you via private message to gather more information from you.
Absolutely what has happened again... all promises and no support.
Just do what you say you will do, when you say you will do it. Simple
Accessing Local Storage
