I tried to enable Video Verification in Arlo Secure following these instructions:
https://kb.arlo.com/000062863/What-is-Arlo-Video-Verification-and-how-does-it-work
After enabling the Video Verification setting for my Arlo cameras, they seem to automatically disable themselves after I check again in an hour. I am using the Arlo Android app on Android 14, Google Pixel 8 Pro. Reproduced this multiple times.
See this screenshot:
Hi @AnonHero
Thank you for the update. Are you still experiencing this symptom with the video verification?
Yes, I tried again today and have the same issue.
When I enable Video Verification (flip those toggles), exit that page by going back to the Dashboard, and check the Video Verification page again, the toggles are enabled.
But when I check again after some time (like an hour), the toggles are disabled.
I also just realized that if I force quit the app after enabling Video Verification, and open the app again to check, Video Verification toggles are disabled again. It's as if the Video Verification settings never get saved permanently.
I also see from the Home Monitoring Certificate that Video Verification is not enabled (this is how I found this bug):
Which version of the Arlo app do you have installed?
Android app 4.12.5_28655
@AnonHero Thank you for the update, I have notified the team and I am waiting for more information.
I was able to get the Video Verification setting enabled on the iOS app. So it seems like this is a bug specific to the Android app.
@AnonHero Oh, thanks for that additional detail. Do you mind providing me with the model and OS of the IPhone?
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
