In the new application I can’t make the cameras turn on and off at the same time
how to make one camera turn on and off at a certain time?
@Roman119 wrote:
Tell me how to get the old application back?
The app is the same but it supports both the old user interface (UI) that uses Library to view recordings as well as the new UI that uses Feed. Once migrated to the new UI there's no going back. Eventually everyone will be automatically migrated.
Start byt reading the FAQs here, including this one:
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
How can I make one of the three cameras turn on and off at a certain time?
Did you read the link above and follow along in your account? There's a section on scheduling near the bottom.
yes, I read the guide
I have three cameras, how can I make these cameras turn on and off at a certain time?
in the schedule I can turn on and off “modes”, how to turn on and off exactly “cameras!” by time and not a mode? how it was done in the old application
For example; the first camera turns on at 06:00 and turns off at 13:00, the second camera turns on at 12:32 and turns off at 00:01, the third camera turns on at 02:56 and turns off at 23:00, how to do this?
Instead of choosing Change Mode when adding an action, look further down and select Record a Video. When you click Next, you get to choose the appropriate camera to be used.
I chose recording, but the video camera does not record when a person enters the frame
explains how to do this?
Lord, why did I decide to update this application((
how to make a schedule like this? how it was here
That's not a schedule automation that's needed - you need to add geofencing ones. While schedules can be used with GF, you need to start with adding TWO GF automations - one for Leave and another for Arrive. Use the + at the top right and choose to Add Arrive/Leave.
I added geofences
I need to make schedules for turning cameras on and off, as was done in the old application
The new UI doesn't work like the old one. That's where following the directions in the FAQ helps.
Choose to add a schedule by selecting Routines and the Automations. Click on the "+" at the top and choose Add Schedule. Give it a name and then Sunrise to set up a custom schedule as you need. Set the days and time to activate and Save. Then Add an Action as desired (perhaps a mode change or use one of the selections below that to activate only a particular camera). If necessary, add more actions, saving as you go.
Create more schedules for different times. You only start a schedule - creating more schedules turns off the previous one and starts the new one.
I studied the guide completely
Did I understand correctly that all these switching on and off work through modes?
how to turn on a certain camera so that it triggers movement?
You've confused me even more.
Yes, any switching of cameras to be on/off is dependent on what mode is active. The scheduling simply switches the modes automatically.
You have 3 modes to work with. While they are named Arm Away, Arm Home and Standby, you can use them as you wish. Arm Away automatically has all cameras enabled but you have to create appropriate rules for the appropriate cameras in the other modes. It's really no different from the old UI, it's just set up in a different way.
It is very different, unfortunately(
For example, if you have 6 cameras, how can you make them turn on and off at different times? you get only three modes, the first is all cameras are on, the second is selected cameras, and the third is all off, and how to work through three modes with all six cameras?
I figured out how to turn two cameras on and off at night through modes. Now my question (my headache). How can I turn off one of the cameras that works at night (in my case it is the “door” camera), and at the same time turn on the camera (under the name Swimming pool) so that it works in the daytime until 13:00 and then turns off?
At the same time, all three cameras should be in Arm Away mode, two cameras should be in Arm Home mode (for night time), and the third Standby mode should turn off the cameras. Where can I get a mode for one camera that will be turned on during the daytime?
Turning cameras on and off only through modes, did I understand you correctly??
You don't always have to change a mode. As I mentioned in post #9 here, rather than selecting Change Mode when adding an action, try using Record a Video which then allows you to pick a single camera to work with. You can have multiple schedules to accomplish a general setting as well as specific ones.
Please show this clearly, for example with a screenshot.
I tried different options but unfortunately nothing worked for me 😞 thanks
Hopefully these screenshots help. Note what is selected in the various screens. If not, perhaps you need to talk to a friend/neighbor to see if they can figure it out.
I hate the new app!! Goes with the removal of email notifications with video links and forced removal of 7 days of free cloud.
I really need to sell my cameras and go with a competitor.
7 day cloud storage is still available for the legacy cameras, so nothing has changed there.
All currently sold camera models need a subscription for cloud storage, but that is old news (going back to 2018).
Guten Tag, ich versuche auch schon seit geraumer Zeit für meine 4 Kameras einzelne Zeitautomatisierungen einzustellen. Das mit dem aufzeichnen einstellen ist nicht das Problem das ist die auswahl der betreffenden Kamera möglich. Nur wenn es darum geht, die Endzeit der Zeitautomatisierung für die betreffenden Kamera einzustellen, ist die Auswahl der Kamera nicht möglich/vorhanden.
Woher soll das System wissen welche Kamera zur gewünschten Zeit nicht aufzeichnen soll?
Grüße
This link should help with the automations
https://kb.arlo.com/000062942/How-do-I-add-a-Schedule-Automation-to-my-Arlo-system
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
