Salve a tutti,
Ho 2 quesiti
1 Appena comprata 3 mesi fa la telecamera sono riuscito a cambiare la suoneria di notifica e adesso neanche riesco più !!
Mi date procedura passo passo per android??
2 Avevo abbonamento da 4.99 euro per singola telecamera e ora nonostante sia rinnovato per un mese mi hanno tolto i feed le registrazioni!!
Mi potete aiutare
Grazie 😉
Can you check for the Settings > Apps > Arlo Secure > Notifications > Notification categories> Notifications> Sound > Notification categories section
Yes i know this.... But i see only active notifications and disactive notifications
Do you have any other options like this?: ""On your phone settings, Can you try navigating to Settings > Apps > Arlo Secure > Notifications > Select Notifications > Sound > Change sound > Save.""
Only this.... It's impossibile to change
Make a screen on your app please
I have escalated this to the appropriate team and support will be reaching out to you as soon as possible.
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
