I havent been around in a while. Right now, we have 35 ARLO cameras monitoring our Lake Community. All working just as we wanted to.
I just installed two new ULTRA2 cameras. I generally install them on my private base, get them working and then reinstall on the appropriate club Lan Base.
I wanted to add these two new cameras to my unlimited camera subscription. When I went into Settings , the
Subscription tab was grayed out, I could not click on it.
If I remember correctly, I can only do this on the web interface. I want to cancel the trial subscription for each of those two cameras and add it to my subscription. But without being able to click on Subscription in the Web interface, I can not.
Hope someone can point me in the right direction.
Happy Holidays to the ARLO staff and all of the ARLO community
Are you using a PC, or are you trying to run the browser on the phone?
Also, what browser are you using?
But on the MAC, I can open Arlo Secure and get to my subscriptions. Indicates I have 7 out of 9 participating. I then used the method to drag a new camera to the subscript area. That function did not work. Normally If I clicked on one of the cameras the 3 lines to the right would be bright and I could move the cameras up or down. Then I figured I would have to cancel the trial subscription which expires at the end of January. If I remember correctly, I was able to do that on my Web Chrome cancelling the trial subscription for that
camera
@rdilauro wrote:
Then I figured I would have to cancel the trial subscription which expires at the end of January. If I remember correctly, I was able to do that on my Web Chrome cancelling the trial subscription for that camera
I don't think you can cancel the trial anymore. It's supposed to transfer seamlessly to your paid subscription, but best to check that when the trial ends.
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
