I have 4 Arlo Q cameras but my backyard camera is refusing to connect stating only 5 cameras are allowed (see photo). Even when I stop the streaming from the other 3, the backyard camera still gives the same message. How can this be fixed? Thank you!
Hi @ArloJesse
Have you tried to remove & re-install the Arlo app?
Is this the old Arlo legacy app or the new Arlo app version 2.8?
Is this displayed in the web browser and Arlo app?
Hi @ArloJesse
Hi Shayne,
@ArloJesse wrote:
However, I am confused about the Arlo App version 2.8 that you mentioned. I only have theArlo Legacy App (for my iPad). I could not find the App you mentioned in the Apple store.
It's there (distributed by Arlo Technologies, not Netgear). You will need to switch to it by the end of the month.
There have been a lot of issues reported here, and it was updated yesterday. So maybe wait a little bit, and monitor the forum before you switch to it.
Thank you, StephenB. I searched under "Arlo Technologies" and found it. I will look to see if there is a newer version for my PC also. Thanks again!
There is no PC app, you just use your web browser as before. Though you should be browsing to my.arlo.com, and not the older arlo.netgear.com.
Thank you, StephenB, for letting me know that. I'm using the my.arlo.com site which works great for me. Thanks for your help!
Arlo Q
