When I arm or disarm cameras in mode it says getting information will not say armed or disarmed worked fine for 7 years now all of a sudden this
7 REPLIES 7
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
Unpluged cameras , reset router& base deleted app it is only cameras that are plugged in
Does this occur over the web portal as well?
Yes
Have you tried removing and re-adding the camera?
Did not try removing camera don't know what reading the camera means
I think he meant "re-adding".
Arlo Q
