  • 5 Replies
  • 1653 Views
Foques
Folks,  how do I do the soft reset/reboot via application?
When I go to devices -> camera -> settings -> device info I have only the "remove device" option.
Two cameras stopped charging via solar, and I wonder if a reboot will save it. Really don't want to crawl 20+ feet into the air..
When connected to a base or hub, you have to reboot that, not the camera. If you really want to reboot the camera, you need to reinsert that camera battery.
5 REPLIES 5
Foques
well, that's silly.
Is the base restart restarting all connected devices?
Basically. The connection is re-made which possibly causes the camera to reboot - can't say for sure but I know it works.
Foques
not a fan of that, but I appreciate the info! have a good day
@Foques wrote:
well, that's silly.
Agreed.  It should be possible to reboot any on-line Arlo camera from the app.  Unfortunately Arlo doesn't seem to get that.
That said, I always recommend putting the cameras somewhere that is reasonably accessible. Even with a solar panel, my cameras still need to be charged from time to time.  And there have been times when I've needed to do a factory reset a camera that went off-line.
