Base station going offline regularly. Tried resetting and re-adding. Middle green LED flashes.
My base station regularly goes off line. I’ve reset it, removed it a couple of times and re-added the base and cameras. Will work for a while and then go off again. Frustrated that I need to re-add it all again. Any suggestions on how to fix? Ironically the middle green light flashes to show connection with Arlo servers.
Have you force-closed the app and reopened it or tried a browser to see if that makes a difference?
