You would want to configure your EX7300 in wireless bridge mode, which would connect the extender to your main router wirelessly, and than you could connect your Arlo Base into the gigabit port on your extender I would think....I use the EX7000 which has 4 wired ethernet ports so that is how I connected my arlo base, but my extender is in access point mode.
Sorry, let me be more clear on my setup. I currently have TWC internet connected to a NetGear X4S router, then upstairs I have the EX7000 connected via ethernet to the X4S to extend my WiFi. Then I have my Arlo Pro base connected via ethernet to the EX7000.
I was going to ask you what you use for your router, but I see your Verizon Novotel T1114v is a router in it's self. So I would think you would be able to connect your EX7300 or EX7000 to your Novotel device wirelessly, and than use the ethernet port for your Arlo Base...But I think the EX7000 is just more versatile with the multiple ethernet ports.
But in saying all that, I can't guarantee anything, because I have never used the Novotel device and not sure if extenders can connect to it.
