Arlo Pro Geo Fencing on Schedule
I’m trying to setup geofencing using the schedule feature but I’m not sure where the schedule gets assigned. There’s no option to set a schedule in geofencing..
Franklinclark08,
Once you have your schedule created. You can then edit Geofencign and select "Schedule" for the "Home" or "Away" Geofencing mode. A commmon setup for this is having "Schedule" in the "Home" slot and "Armed" in the "Away" slot. This will mean your cameras behave according to the schedule when you are home and are always armed when you are not.
So the schedule used is the one setup in the previous screen where you can set it to run solely on the schedule?
Correct.
