Uk
Hello, I am experiencing high drainage with the device toggled to off. Why? Thanks
Even with the camera set to "off" it's still communicating with the servers. That leaves the signal strength/quality as the likely suspect. If you bring the camera closer to your router or hub, does the battery life improve? If you have more than one camera, swap them around to see if the issue is the location or stays with the camera.
Hello,
thanks for message. I have swapped them around. The camera is closer than others that don’t suffer the same drainage. No idea how to improve?
One other thing to try is to swap batteries around since it could be a faulty battery. Once you figure out whether it's the battery or camera, use the app to go to Settings, Support and choose your camera. Scroll down to Contacts to talk to official support to see what they may offer.
Thanks for advice.
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
wind
Zones
