I have 4x Pro 5S cameras and had a super troublesome time connecting the first two and now the last 2 just won’t connect. QR code gets scanned, I hear the chime and then after 10-15 seconds of the light flashing blue, it just stops, followed shortly by the big red “X” and “no cameras were found”. Unbelievably frustrating and almost considering throwing these last 2 cameras in the bin. Any help before I do would be greatly appreciated
I'm in the same boat except mine were already setup. Now none of them will connect on either browser or Android app.
These things are too expensive to be this unreliable.
Have you tried resetting the cameras?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
FOr those that are already connected, try removing one from your account, reset and reconnect using the same procedure.
Mine are actually still capturing motion but I can't go to the live view. It says "connecting" for 2 seconds then stops.
100%, never had an issue with similar, less pricey products. It’s super frustrating.
It proves nothing but my Pro 5 is streaming fine. Have you tried rebooting the camera or hub?
Yes, that’s al I have been doing is resetting them. I finally just got the 3rd one running after numerous resets, might just have to do the same with number 4
5s
Accessing Local Storage
Accessing Local Storage.
Arlo Cameras
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
drained battery
low power mode
Magenta screen
metal barns
Night vision
No recordings
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
Wifi connection
wind
Zones
