Arlo won’t discover device . Phone and camera on 2.4ghz WiFi. Lights blinking, chime sounded. What else can I try?
device has been working great for a year and was disconnected accidentally when brought in to be charged. Now it won’t re-connect. thanks for any ideas
Thank you StephenB!
Hard reset thru PC didn’t work but tried again thru iPhone - success!!
Thanks so much for sharing your smarts😊
Try using a PC browser (my.arlo.com).
Thanks so much for your input. Tried using my PC and even tried a direct connect camera to pc via USB but the camera is still not being discovered. Very frustrating!
Really appreciate your time.
Thanks 😊
That definitely won't work.
You might try a factory reset (holding down sync until the camera flashes amber - about 15 seconds).
Thank you StephenB!
I'm glad you got through it.
Arlo Pro 4
labels
Samsung SmartThings
