Pro 4 not picking up motion, battery issues, etc.
- My pro 4 is on CVR. Even while plugged in, the battery would last around 24 hours. Replaced with another battery, same thing. I couldn't view live, but it would pick up motion. So I removed the camera, then reconnected. Now the battery last maybe 48 hours, and now no motion detection. I can view live though, but no good without motion detection.
- Any ideas?
I am thinking the charger isn't supplying enough power. Do you have another one you can test with?
CVR should work with AC power even if you remove the battery altogether.
Arlo Pro 4
labels
Samsung SmartThings
