I'm getting low temperature warning on 1 camera - I LIVE IN FLORIDA
help. all was good with my 3 cameras until yesterday. One camera is giving me a low temperature warning. It will not reset via the app on my phone. Nothing occurs.
I LIVE IN CENTRAL FLORIDA AND IT IS SUMMERTIME. so clearly this cannot be right!
what do I do? I tried taking it down and taking the battery out then back in
TJC1962,
What error message are you seeing? Are you able to provide a screenshot?
If you remove the device and resync it, do you still experience the same issue?
I just posted it elsewhere. I removed it
now it won't let me re-add it. I get the chime. I added my wifi. but it can't locate the camera
TJC1962,
You may need to factory reset the camera before being able to add it back. Take a look at the instructions here: https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Pro 4
labels
Samsung SmartThings
