How do I adjust the activity zone?
Go to the camera settings and choose Activity Zones. Click the "+" sign at the top right of the screen and adjust as needed. If trying to adjust existing zones, select the specific zone under the image and adjust as needed.
Thank you so much! Could you also tell me the logic of having more than one zone for a camera? Why not just make the activity zone cover the entire area that you want to video because if you divide it up into five different zones, won’t you get a notification every time there’s activity in each zone anyway?
Generally people use it to cover an irregular region.
While you can make a single rectangular zone that is larger, that might include areas you don't want to trigger on. For instance, a town sidewalk that might be at an angle to your camera.
Arlo Pro 4
labels
Samsung SmartThings
