@HMishkoff wrote:
You say that decoding is done by the PC hardware. Are you sure it's that simple and that there's no a video player involved in the process somewhere?
Arlo uses HEVC compression in their 2K and 4K video recordings.
- That requires hardware acceleration to be enabled in Chrome (and a PC that has hardware acceleration for HEVC)
- Edge might not need hardware acceleration - a while back it didn't, but then a Microsoft update changed that. I'm not sure if that was a bug or not). Either way, Edge needs the Microsoft Windows extension for HEVC.
- Firefox doesn't support the codec at all.
I haven't studied the my.arlo.com html in any detail. But if you drag the mp4 into Chrome, it will play using only facilities built into the browser. If that is also choppy, it rules out my.arlo.com and the Arlo Cloud infrastructure.
Back when I used to develop websites (a long time ago), I could embed video players in a web page if I wanted to show a video. I assume that's still possible. And I know that it's also possible to embed videos from other platforms, in which case you're using that platform's video player. And I think that HTML5 has its own integrated video player. I have no idea how Arlo plays videos on their web pages. All I know is Arlo's videos have always played smoothly on their site, now they don't anymore.
When I download one of the videos, I can play them locally (and smoothly) in maybe half a dozen different video players. However, I can't get the downloaded video file to play directly in my browser.
I've bee running it in Edge. I downloaded the HEVC extension (had to shell out $1!), didn't help, still choppy.
As you say, it doesn't run in Firefox at all.
But I discovered that it works perfectly in Chrome. Thanks for the suggestion, I might not have thought of that simple fix on my own.
Arlo Pro 4
labels
Samsung SmartThings
