I am getting a "website not secure" message from all browsers. Sounds like a security certificate needs renewing.
If i click onto my arlo i can get on my cameras from there
Arlo web site generates this message:
Secure Connection Failed
An error occurred during a connection to arlo.netgear.com. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP
Website has been down for past two days. Using camera is not an option or relevant to issue.
You are getting this error because you are still using the old Netgear URL (arlo.netgear.com). Arlo hasn't been part of Netgear for 5 years now.
You should be using the current URL ( https://my.arlo.com )
Arlo Pro 4
labels
Samsung SmartThings
