I moved my Arlo pro 4 to a different house where I originally used it. I have connected it to the wifi where it is currently hanging, but the wifi will be turned off soon. Can I reconnect it to my wifi back to the wifi it was connected to at the previous location to be able to get live views or alerts, or does the camera need to be connected to a wifi in the location the camera is at.
The pro4 camera requires internet access either by direct connection to the local wifi or via a base/hub connected to the local network that has internet access.
You should be able to go to the camera's settings and select Connected To. At the bottom is a Change Network which allows you to connect to the new WiFi without removing/resetting the camera.
Arlo Pro 4
labels
Samsung SmartThings
