Arlo Pro 4
Also battery life should be 6 months and I have solar panels attached to them and they are not lasting that long.
And finally on occasion I would have to reset my camera. With all these issues how can I rely on the cameras for the safety of my family?
1) Swap cameras around to see if it's the camera or location causing the lack of recordings. Also read the FAQs in the support section here on best camera positioning practices as well as changing motion sensitivity (and other settings) in your modes and rules.
2) Battery life, even when connected to a solar panel, depends on many things including the total amount of time spent each day recording and live viewing, signal strength/quality issues, etc. Be aware that if you're using Arlo Smart and/or zones recordings are still being made but the servers may be deleting supposedly unwanted videos due to your settings. You don't see the videos but they were still made. You can test this by removing the zone and disabling the camera in the Smart settings.
3) Define "reset" - remove and reconnect the camera? If you have to do this, see #1 which could be the reason for any disconnects, especially the part about signal strength/quality.
Thanks for responding
Arlo Pro 4
labels
Samsung SmartThings
