Arlo Pro 4 keeps going offline and online on it's own. My two other cameras have no issues and this one has a full strength WiFi signal. It is also at the latest firmware,
Anyone else have a fix for this?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Thanks for your response.
I have checked Firmware, reset camera and removed and re-added to the app. Also have moved my WiFi router so there would be a more direct Line of Sight to the camera.
@rocster0289 Can you PM me with the serial number of the affected device?
Arlo Pro 4
labels
Samsung SmartThings
