  • 17 Replies
  • 883 Views
rchen119
I have Arlo Pro 4 XL, I am on iPhone iOS 17.1.2.  The Arlo notification has no problem to show in notification center, but there is no badges on the app icon.  Any help is appreciated!   Thanks!
17 REPLIES 17
BrookeN
Under settings within the iOS app ~ then under Arlo, is the badges turned on?
rchen119
Yes the badges is on. Thanks!
BrookeN
Uninstall the app from the library ( if it says remove app you are in the wrong spot) Reinstall the app and see if the behavior is resolved.
rchen119
I tried to delete Arlo app (can't find uninstall) from library, then reinstall the app, but same issue occurs.   Thanks!
BrookeN
If you swipe left on the iPhone until it shows library and then hold down the Arlo app it will say uninstall. Let's try to do it that way first.
rchen119
After hold down the Arlo app, it only lists the following:
Delete App
Share App
Arm All
Disarm All
Schedule All
BrookeN
Delete app and then reinstall it from the App Store. Then sign back into the Arlo app and see if the same behavior happens.
rchen119
Thanks!  I deleted app and then reinstalled it from the App Store, but still having the same issue.
BrookeN
Are you able to see those badges now?
rchen119
Unfortunately, still no luck.
BrookeN
Which iPhone are you using?
rchen119
iPhone 14 pro
BrookeN
Thank you for providing that information. I passed this onto our development team and will reach out with an update as soon as possible.
BrookeN
'Are you still experiencing this same behavior?
rchen119
Yes
rchen119
I have not received any updates from development team yet.
BrookeN
Can you try logging out and logging back in. I know it seems like a simple fix, however I was seeing this same behavior. And that resolved it for me.
  • 17 Replies
  • 884 Views
