  • 7 Replies
  • 674 Views
Hansy
Unable to view locally stored videos through app. Rebooted and still did not help
7 REPLIES 7
Did you reinstall the app? Have you checked the local storage settings for base/hub to see if the available space is going down? How about safely ejecting the drive and viewing on a computer?
Hansy
Yes tried rebooting - no I don’t want to eject and check on my computer- it should work through the app
dcfox1
I think @jguerdat meant just trying to eject and viewing in the computer to check if local recording is working at all.
Yeah.  And it also lets you see if the USB storage has failed or not.  I also suggest trying this - and while you are at it, see if you can copy a file to the USB storage.
If Windows offers to "repair" the USB file system, then let it do that.  That could be the problem.
I didn't ask about rebooting since you already had said you had done that. I asked about reinstalling the app.
Hansy
Yes - I removed the usb safely and was able to view on my computer just fine. I would like to view via my app though as it saves me time
Some of your posts have the VMB4500, others have VMB4540...
That can only be done with the smarthubs (VMB4540 and VMB5000).  Not the VMB4500.
If you have a VMB4540, have you enabled direct access to local storage in the base settings?
  • 7 Replies
  • 675 Views
