My cameras were working for the last 2-3 months. My cloud service expired. The recordings are not showing up in the library. Do I need to put a USB drive in the base for the recordings to show up in the library on my phone?
Please help. Thank you.
Without a subscription your only choice is to record locally so, yes, you need to install a USB drive (a thumb drive is recommended for space needed and ease of removal).
Thank you.
CDPerron,
What mode are you using? Are the rules set up correctly for the Pro 3 camera?
Is there any way I can get on the phone with you? It appears that this is an extremely common issue.
CDPerron,
If you would like to contact support and speak with someone about this issue, take a look at the options found here: Arlo Support Center
