Had Arlo pro with subscription for years. Now, Arlo pro 3 and free subscription ran out and now I've got problems. Not supposed to be necessary!
@Elkinde wrote:
Restarted everything and the base shows a solid blue light. Should be good! Nope. Arlo app shows everything is off line.
Did you try the full factory reset? https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
@Elkinde wrote:Had Arlo pro with subscription for years. Now, Arlo pro 3 and free subscription ran out and now I've got problems. Not supposed to be necessary!
What problems are you having? You will lose some options like cloud recording without a sub.
VMS4240P-100NAS. Hub has to constantly be rebooted, "unrecognized format" message on local recording when trying to view, poor night pictures when I can view them(badly pixelated).
All this suggests a connection issue between the camera and the base.
Are you having any issues with live streaming?
Have not had any streaming issues from my phone.
Maybe try testing the USB drive? Or use a different one if you have one handy.
You could also try directly accessing the drive on a PC, and see if you see the same problems as you get when using direct access to local storage.
Used 3 different USBs already. Unplugged everything a week ago and took it in to Best Buy and they told me all I could do is contact you. "Not Happy". Will plug everything back in this weekend and give it another try.
Not me - this is a user forum, and I don't work for Arlo.
So we're up and running again. Thanks! Can I get back to you if I run into these problems again?
So now some videos are viewable and others(majority) are "unrecognizable format".
Hi Elkinde,
Is this happening on both the web client on your computer and/or the Arlo app on your phone device? Could you show a screenshot where it's showing "unrecognizable format"?
On my phone, all I can view is live streaming. On my computer I was opening up the downloaded pictures with Windows Movies and TV, but now they are "unrecognizable".
Try using VLC and see if that works. https://www.videolan.org/vlc/download-windows.html
