Outdoor Mounting
Is the outdoor mount for the Pro 3 just the magnet mount? At least with the Pro 2 there was some ‘screwing’ to secure them to the mount, which meant it took some effort to steal. With just a magnet mount, someone could knock it down with a stick or potentially just pull it off the mount.
Trying to decide if I should upgrade or avoid based on the outdoor mounting options.
JMWolf,
Arlo Pro 3 can be mounted using a magnetic mount or a threaded mount, like your Pro 2.
All Arlo cameras support the standard screw thread that cameras use to mount on tripods or any other device.
Just another user
