I have multiple towers and I would like to mute one but not the others. Is there a way to accomplish that?
When referring to towers, do you mean the arlo Base station/hub?
When you refer to mute do you mean using the mute notifications option to stop the notifications?
Mute notifications feature stops all the notifications being sent to the mobile arlo app. Recordings still occur in the background.
What version of the arlo app Ui do you have, will depend if it is possible for what you’re asking.
