  • 13 Replies
  • 4597 Views
  • 9 In Conversation
GarretBryl
I have 9 Pro 3 cameras and the Smart Premier account.  Three of the cameras were on trial subscriptions that have run out but the online tools won't allow me to add the three cameras to the account (supposed to support up to 10).  I have tried dragging them to a slot in the "manage cameras" online utility.  It shows "wait" but then nothing is accomplished.  Any ideas?
13 REPLIES 13
GarretBryl,
We've opened and escalated a ticket on this issue to the development team. I will provide an update when we have more information.
bryanlyle
Any update on this?  I have several Arlo Pro's that I can't add to my Arlo Smart Premier plan.  The only camera that shows up is the Arlo Pro 3.  If I try and drag any of the Pro's, they won't move.
wooj001
My Arlo Smart Premier subscription won't allow me to Add - Back my existing 6 cameras after the 3-month Arlo Video doorbell Arlo Smart trial ended.  I still have my plan, but it only supports the video doorbell. According to Arlo, my six cameras Do Not have a plan, and it won't allow me to drag it back to include it as part of my plan.
Help.
Phoney49
Luminary
Luminary
I have the same issue, only with an Pro 3 3 month subscription that ended this week. It is now the only camera receiving Smart Notifications??? I cannot add my other 3 cameras even though it says I have the option to add up to 10???
In the Smart Notification section, all 4 cameras are active. In the subscription section, only 1.
Phoney49
Luminary
Luminary
Fortunately I seem to be getting Smart Notifications anyway.
bryanlyle,
There were same changes made that should alleviate issues with managing active cameras within subscription plans. Are you still experiencing this behavior?
dcfox1
I still do but just on web portal, says I cant add any more cameras says max 5 and none are shown as active. On app it is fine and have smart options and seem to be working. I am on trial period.
JeaniB
I only have two cameras participating in my Premier subscription. When I go to manage devices it tells me to "drag the camera". I don't see any camera to drag? How can this be fixed as only 2 of my 5 cameras are participating.
JeaniB,
Cameras that are not participating should show under "Inactive" cameras. Drag the cameras into an active slot to move them into your existing plan.
rhabdox1
Hi, I purchased 2 x Pro 3 floodlights, which come with a 3 mth trial each. How do I get my current smart plan (on a Ultra Smart Hub VMB5000) to be extended by these trials? I added one floodlight and it indicates (in a blue box on the app) 3 mth trial which is running concurrent to my existing smart plan and expires 9 months earlier than my existing 1 year smart plan. The added floodlight indicates it is not on my current Smart plan and I can't drag the camera to add it to the plan. Thanks.
rhabdox1
Trial plans cannot be used to extend existing subscription plans. Trial plans are automatically applied upon installation, once the trial expires (or is cancelled) you will be able to add it to your existing Arlo Smart plan.
JOmoore
I have same issue.  Now Arlo Pro 3 Cameras stuck in one month trial.  I have room for 4 cameras on premium plan and I cannot add them.
dcfox1
Just like JamesC said in prior post you will be able to add them when trial expires for those cams as long it is a max of 5 cams.
  • 13 Replies
  • 4598 Views
  • 9 In Conversation
