I just purchased and Argo Pro 3 system. The quick guide says to put in batteries and charge. It doesn’t say how to tell if charging and when charged. I tried to search the manual. Nothing. Search internet and can only find for older models that say a light will turn blue. I’ve had one plugged in 12 hours and still no blue light. Anyone know how you tell if currently charging? Then how to know when charged?
It may be that the power connection hasn't actually been made. You should be able to sync the camera with the existing battery condition in most cases so try doing that. You would then be able to see the battery percentage as well as determine if power has been connected (the battery icon would have a lightning bolt across it).
When first connecting power, the blue LED should briefly flash to let you know power is connected. Does it do that?
@nate99 wrote:
The blue light came on when plugged in but didn’t stay on.
That's right.You now know that charging has started.
The LED will turn solid blue and stay on when the battery is fully charged. At least, it will unless you have disabled the indicator.
Just another user
