- English
- Floodlights
- Arlo Pro 3 Floodlight
- Pro 3 floodlight I opened the case to install the ...
Case will not lock in place
It can sometimes require quite a bit of force. I've sometimes taken the camera down, which gives better leverage. Then reattach it to the mount when it is locked in place.
But I think a better approach is to get some silicon grease, and apply to to the o-ring.
FWIW, I just live with it but really should grease the seal. I place my thumbs on the edges of the camera face, wrap my hands around the case and press.
