- English
- Floodlights
- Arlo Pro 3 Floodlight
- Floodlight will flash multiple times when in light...
Floodlight will flash multiple times when in light mode only, works fine when armed
Been having issues with my floodlight. it worked fine for a few years but now giving me issues only when its scheduled to act like a floodlight and not camera. When its armed it turns on and records for the time it needs to. However when I set the schedule to turn on light and not record so that I can use it a flood light during the evening and don't need to record it turns on for like 3 seconds then off and does it again and again and eventually it will stay on for a bit.
I thought maybe my light was broken but I have another one and it is doing the same thing so I think its the software.
I have done everything, removed it, reinstalled it, new battery, paired it to the wifi, paired it to the hub, changed every single setting there is and still not working.
Screenshots of your rule as well as the floodlight settings may help us.
