I run my arlo pro3 floodlight on solar. Its been great till 2 days ago it was at 100% power then it suddenly dropped to 1% and then died an wanted charging. I took it off the wall and it went back to 100%. So I put it back on the wall. A couple hours later it's dropped again to 1% and it's been like that all day. Anyone else had this problem
I've seen a couple of reports of this with floodlights (and at least one with an Ultra).
Perhaps try disconnecting it from the panel, and see if the battery works normally.
@JamesC , @ShayneS : Is this an issue Arlo is investigating?
Arlo Pro 3 Floodlight
