My fl1001 floodlight 3 camera won't connect. I have T-Mobile and an Arlo hub with 17 working camera already. I go thru the app and choose my camera and try it auto then manual. It blinks blue then amber but just keeps searching to no avail
Are you trying to connect it to WiFi or the hub? Have you tried resetting it?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Pro 3 Floodlight
