Can not get a straight answer for this some say in some say out. When using the arlo outdoor power adaptor to AC does the battery stay in or will it work with battery out?
I think it is a good idea to have a working rechargeable battery in the camera, even when on AC power. Some Arlo cameras do not have a battery, and for these I maintain a smaller UPS system in line for each. I also provide a UPS to power critical networking components (Arlo Base station, Router, etc.).
By having some form of battery backup you have some coverage, for some period of time, in the event of a power outage (accident, natural disaster, bad guy trying to kill power, etc.). This can keep local recording functions working onto the backup UPS flash drive, or to you through the Internet, as long as your system continues to have Internet access.
M
It will work with the battery out.
We have been working on this for over a week, Trying different extensions etc Camera worked well for a long time then kept getting message it had no AC power to the outdoor power adaptor. We found the problem We had three outlets put in on the porch for pond pump, lights and camera. When my husband was cleaning the pond he shut off the outlet for the pump and the camera stopped working. He just realized the electrician installed the main switch for the camera outlet upside down so off is on and on is off. Hubby thought the main switch for the camera was on but it has been off. Boy do we feel dumb. Thank you all for the help.
M
