I'm looking for places outside to hang the Arlo Pro 2. Ideally, I could wire it.
I thought of a cool option. I could install flower boxes below the upstairs windows in our house, then put an Arlo Pro 2 inside one of the flower boxes. It would be a great hiding place I think. It's an easy spot to replace the batteries (reachable by opening the window), or a simple hole under the window to an outlet to leave it plugged in.
I think I'd have to create a small compartment for the arlo, as it wouldn't do well lying in the soil, being wet all the time, right?
Hi @bbeagle
That is a good idea however there are some guidelines for proper placement and best performance. I have provided an article that will help with the placement of the camera.
