Jamesgd,
What is the issue you are experiencing with your device?
The device no longer works. Ever since the update the device will not connect. I have tried different batteries and chargers and I have called support multiple times having them walk me through the process. Sadly it just does not work since the firmware update. Since I got the device a little over a year before it was no longer under warranty. My other devices have not had these issues. I personally find it ridiculous that I have a very expensive paper weight of a camera now due to a firmware update. Please feel free to email me for fastest response.
Have you tried removing the camera from the Settings > My devices then re-add it? Does the Camera turn on when you insert the battery? What are the status LED's when inserting the battery?
