  • 5 Replies
  • 1226 Views
Smokey14290
Does the Arlo Pro 2 cameras talk to the basestation that then sends the video via the LAN to the cloud or does the camera.?
The base is the intermediary. The camera only talks to the base.
5 REPLIES 5
Smokey14290
So the basestaion can be plugged directly into the LAN port of my Google Wifi I assume.  Has anyone used the Arlo Pro 2 cameras with the Goggle cluster?  Google claims it supports connections on the 2.4, but of all the devices I have connected, not one will connect to the Google clusters, so I had to install a second 2.4 router.
JessicaP
Hey @Smokey14290,
Just to make sure, are you referring the "Google cluster" to the Google Wifi?
Smokey14290
Yes, a google wifi/router cluster.  I haven't found a device yet that will connect at lower speed.
JessicaP
What is your Arlo Base Station model? And what problems are you having when connecting your Base Station to the Google Wifi router?
  • 5 Replies
  • 1227 Views
