Can the arlo pro 2 be connected to the plw1000?
Tom Mac (guru)
thanks regarding arlo pro 2. I misstated my question but you answered it anyway. I really wanted to ask if the base station could be attached to the Plw1000 extender and that is what you've confirmed.
@TomMac wrote:
No the Arlo / Arlo Pro /Arlo Pro2 ONLY connect to a base unit.... but you can centrally locate the base unit using the extender ( if it has an ethernet port ) to better reach all your cameras ( or use multi bases, as there is no limit to the number of base on any service plan )
Thanks again.
Tom Mac (guru)
Thanks again.
