  • 7 Replies
  • 2427 Views
  • 2 Likes
Cortizone
Arlo Pro 2 - 5 camera system Installed October 2018 I have all the cameras on the same schedule. All are armed from 9pm-8am. Only one of the cameras is armed from 8am-9pm. Everything has been working fine until last week. The most active camera of the 5 (active because of my dogs) records many events from 9pm until we retire for bed. We usually awake between 7-7:30 am, and I immediately let the dogs out. The camera should detect their and my motion up until the 8 am stoppage, but has stopped detecting during this period. All other hours of the schedule seem to work fine. I have deleted the schedule and reset it with no improvement. Anyone got any ideas on what the problem might be?
JessicaP
Thanks for clarifying. If you use the Arlo app, try checking your schedule to see if it shows correctly as how it is on the web client.
7 REPLIES 7
put that camera in the schedule and during time, confirm that it is actually armed... the motion icon is black.
If NG, then power button reboot the base and/or reset the camera by pulling then replacing battery
Cortizone
Thanks for the ideas, TomMac...
I would still like someone to chime in on HOW this anomoly can happen...i.e. camera records most of the time during the "armed" period, but not during the last hour of the armed period?
JessicaP
Hi @Cortizone,
You can also try testing on the web client on your computer (if the schedule was created through the Arlo app) to see if that may have cause an issue.
Cortizone
What do you mean by testing? BTW, I always create my schedules using the PC client not the app.
JessicaP
Cortizone
Thank you JessicaP...you may have discovered the source of the problem!  When I checked the schedule using the app (as opposed to the web client), only Monday was set as active on the 12am to 8am time slot...the other 6 days were blank!
I activated the other 6 days and will post back tomorrow oon whether that fixes the issue.
Thanks again!
Who would think that these two (app and web client) would update the schedule independently!
Cortizone
Thank you again to JessicaP!!
Your suggestion to check the schedules in both the web client and the app version and make sure they both had the same schedule (mine was different), was the solution.  My app version was not set to record everyday like my web version (not sure how that occurred).  Once corrected, it works as it always had for the past 6 moths.
I let the dogs out at 7:42 this morning and by the time I let them back in, there were 8 recorded events in my library.  YAY!!
Thanks again.
Gold Star to JessicaP!
  • 7 Replies
  • 2428 Views
  • 2 Likes
