The camera pretty much only records in cvr when it wants too. When it needs to be working properly, it doesn't. That is not a good thing when you have a neighbor threatening your life. I have tried resetting the camera and the base. Changing the location of the camera and the base. I have done everything and nothing has helped it.
Hey firephoto23,
Are you not able to see your CVR recordings properly on the web client browser on your computer as well? Make sure your signal strength is showing full bars to ensure a stable connection.
@firephoto23 What she asked was what is your signal strength on each camera out of the 3 bars. It has nothing to do with your wifi internet since they are are a closed system communicating with your Base. Only the base connected to router deals with internet.
