Base Station connection lose after 2 to 2.5 days.
- RSS-Feed abonnieren
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Anstößigen Inhalt melden
Hi all,
My Base Station loses connection to the router. The DHCP enties doesn't show the Arlo Hub anymore ( I have assigned a fix iIP for the Base Sation). Restart of the Arlo device won't help. I have to restart the router and the Arlo device in order to have both working again. But only for about 2 to 2.5 days. A soft reboot of the router dosn't help. It has to be a hard reboot. I guess the Switch on the Router is still powered through the soft reboot, while a hard reboot resets takes power of the build in switch.
Has anyone encountered the same issue? I did factory reset on both devices several times and nothing helped. Issue is only with the Arlo Hub. While it happens with the Arlo Base station, it also affects the SuerPet connect hub, which then cru.
Thank you in advacne for any suggestions.
MacBrain.
- Beschriftungen:
Bevor Sie kaufen
Bewegungssensor
42 -
Dienste und Sicherung
21 -
Risoluzione dei problemi
Versionshinweise
8 -
- « Vorherige
- Nächste »
