I have three separate cameras around my house. I’ve bought them many years ago and I’ve had no trouble. All three have fully charged batteries and are plugged in with chargers constantly. About a week ago all three cameras suddenly stopped recording. I have checked through troubleshooting and other solutions, but nothing is working (direct wired in for internet, took out battery, restarted system, deleted then re-added camera, etc). My system is armed, I have performed motion detection tests and all are working, and I can manually record to my library. Does anyone have a solution for this?
What is your active mode? Have you checked it for rules for the cameras that include recording? A screenshot of that mode may be useful. Normally, unless you've edited it, the Armed mode should automatically have rules for recording for all cameras. Have you tried using that?
I am using the app default “Armed” setting where motion detection is on for all cameras and records for as long as the activity is on. I have even tried making my own but it did not work so I went back to the default
rrock,
Try removing and factory resetting the base station, After the reset is complete, re-sync the cameras and then test again to see if you still experience the same behavior.
For more information on how to factory reset, see here: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
I have exactly the same issue. Resetting, restarting, removing, reinstalling the base station does nothing. The base station and cameras are off Arlo app and Apple Home.
Thanks for the heads up. Most of the suggestions from tech support have been to remove the base station then re-add it back along with the cameras. I’m not sure how but 2 of the 3 cameras started recording again without me doing anything so it could have been just a glitch in my account?
Still not happy about paying for 1 month of the Arlo secure just to speak with chat support. I read on multiple forums that my legacy cameras (Pro 2) still have free 7 day rolling recordings
I have 4 Arlo Pro 2 cameras and all but one stopped recording in my library last month, too! I can view live but there are no recordings. I've had no issues up until now. All cameras are constantly charged, 2 are kept indoors and 2 are kept outdoors and are never moved. Here's what worked for me.
1. Make sure the app is updated. Remove all camera devices from the app. You will reinstall them later.
2. Remove the batteries from each camera for a few seconds and then replace.
3. Reset the base station. Use a paperclip to hold the reset button located in the back of the base for about 10 seconds. Wait about 10 minutes for the unit to reset.
4. Remove all wires (power cable and LAN cable, if any) from the base station and wait 1 minute. Then plug them back into your base station. Wait for about 5-10 minutes. Reconnect your base station to your Arlo app.
5. Now, add your cameras back onto the app.
Very time consuming but this worked for me!
